This is the sharing of info thread, to post pics and possible causes.
These are from a 2009 car, not my pics and if the sender wants to be identified it is up to him.
Here is the pump taken apart. Note the left end of the part labeled 'piston' is where the little tiny roller is located.
Closeup shot of that piston's roller:
Close up shot of the shaft cam that roller rides on:
I have another one here, looks pretty much the same EXCEPT it has no signs of the rusty residue on it. In fact, it is squeaky clean inside.
This is the shaft, you can clearly see how much is worn away at the apex of the cam lobes:
And here is the little roller piston:
Sorry for the crappy focus, my camera is old and my skills are even older. But the wear marks on the roller could very well have been caused by the little roller getting turned off-square from the shaft's cam lobes.
