steve05ram360
why not clean the DPF instead of replace...there is a company in WA that does them.
Yes it is calculated or derived from several factors. there is no direct probe.... mileage and differential pressure are two big factors I assume ECU uses, to name two of them. The mileage is weighted by average speed, mpg? The differential pressure is obviously related to how blocked the DPF is. There are probably more inputs or factors it uses in calculated or derived ash load and oil ash load. It is like Avg MPG on MFD, pretty close but not always right. There are things that can throw it off.You guys bring up some real valid points on the calculations/measurements of the DPF system. There always seem to be some "quirky" values when someone gets work done on the DPF, EGR, etc. After my turbo failure and a lot of oil going into and out of the exhaust system, my DPF values didn't change. Numbers before and after the turbo failure remained the same. My values didn't need reset since the original DPF was still being used, but the "calculated" values had to be off after that ordeal.
Take care and stay safe my friends!
Thanks again for doing all the work for this thread over four years.You guys bring up some real valid points on the calculations/measurements of the DPF system. There always seem to be some "quirky" values when someone gets work done on the DPF, EGR, etc. After my turbo failure and a lot of oil going into and out of the exhaust system, my DPF values didn't change. Numbers before and after the turbo failure remained the same. My values didn't need reset since the original DPF was still being used, but the "calculated" values had to be off after that ordeal.
I read the 2013/2014 2.0L TDI will pass emissions after a DPF delete. Has anyone here done a DPF delete? Someone posted the ECU modification that can be made with VAGCOM.
X2....not a 2010 but a 2014 and maybe when that occurs to me there will be even more places doing that kind of work.Jerry,
If the DPF fills on my 2010, I plan on having mine sent out to be cleaned rather than replacement.
My biggest fear with the DPF delete or any other illegal mod is what happens when the car is sold.
Sure you could sell it to another TDI lover who pays a few extra because it has the delete but what happens when he gives it to his/her son and they take it to CarMax and trade it.
Someone buys it.. takes it for an inspection gets busted, they track it back to you.. Can't see it ending well
For the most part, people who buy diesels generally intend to keep them until the only person who will buy them is the breakers yard! Take a look at the last vehicle in my signature!My biggest fear with the DPF delete or any other illegal mod is what happens when the car is sold.
