aNUT
Welp, I knew we'd be doing them eventually. 140K on the clock. This one had significant chain rattle for upwards of 10 seconds after changing the oil or if it was a very cold start. Intake bank 1 cam phase retard was over 9 degrees when warmed up.
I do not recommend pushing them that far. Probably ought to replace them when you hit the 7-8 degree range. At that point the tensioners can still take up slack so you don't risk skipping time. This one actually skipped after the motor was out & we were rolling it to TDC to lock the crank.
You can see how much more extended the old tensioners are vs the new ones.
