Hi all,
As the title states, I am having severe blow by, but my dry compression numbers are all above 276 PSI. Leaking valve cover gasket (by the brake booster) and there is visible gas coming from the oil fill cap if I open and set the cap on the fill hole.
I have been experiencing random shutoffs when driving it around the block for testing or moving for street sweeping. Does anybody know why this could be happening?
Secondly, what are my options to fix blow by? Change piston rings and hone cylinder or a tested long block -_- Anything else?
Other things to note:
oil pressure is at 40psi @ 2,000rpm when warmed up
I've swapped this into an MK1. It's not the prettiest, but it's in there.
It's in limp mode and I am going through this diagnostics list here
Here are my dry and wet numbers for each cylinder(#1 being closest to the belts):
I got an endoscope camera to shove in the hole from amazon (~$23) to check out the situation too.
(https://imgur.com/a/MVDX3mc)
EDIT (my diagnostic/final stretch of the conversion)
http://forums.tdiclub.com/showthread.php?p=5574302#post5574302
- 365, 425
- 354.5, 425.5
- 379.5, 413.5
- 391.5, 440
