Second generation solutions
Cellulose, the tough molecules that make up cell walls in plants, can be found in a number of forms including straw. However, to break down the cellulose tough new enzymes are needed to act as a biological catalyst and separate it from the rest of the plant to produce ethanol. Shell is working with Canadian firm Iogen and Codexis in the USA to pursue this solution.
Alternatively, gasification can use four sources such as wood chips or waste paper – heating them to a low temperature to create a charcoal-like substance, then at high temperature to produce a tar-free synthesis gas. In turn, this is then converted to a sulphur-free liquid fuel using the same process as to produce exactly the same synthetic fuel, this time BTL (biomass to liquid).
In the future, algae may also provide a sustainable source of vegetable oil for the production of biofuel for diesel engines. In 2007, Shell announced plans to build a pilot facility in Hawaii with partner HP Biopetroleum to investigate the potential. It is early days but algae holds promise because they grow rapidly, and can be cultivated in ponds of seawater, minimising the use of fertile land and fresh water.
Gas to liquids (GTL), biomass to liquids (BTL) and coal to liquids (CTL) are all part of the XTL family - created through the same 3-step process and producing identical results whatever the source material.
