Ryder1032
Hey everyone. Recently rebuilt my 04 tdi with the BEW PD100 engine. Had a runaway and bent rod #4. Honed all the cylinders lightly to clean them up, and a new/used set of pistons from a local breaker with new kolbenschmidt rings and followed steps for ring placement, measured protrusion to a 2 hole head gasket. Head was sent out and decked with new guides and seals with all new valves and camshaft as well as it was also worn and time to replace. Head is totally rebuilt. All new gaskets, seals and o rings top to bottom aside from the crank seals as it wasn’t pulled. Also a new turbo.
I’ve put just over 10,000kms on it since the rebuild. Went to do an oil change the first 5000kms and before I drained, the oil was lower than the first bend on the dipstick. Maybe about 2L in the engine. Since then, I’m adding about a litre every 800-1000kms. Although all seals were replaced, it seems to be leaking at the valve cover, both ends of the PCV valve and oil cap gasket and injector harness o-ring. It looks wet around both the intake and exhaust manifold bolts but can’t tell if is just wet from the valve cover. It will also give a small puff blueish white smoke if I give a little rev when I back into the parking spot at work. Not too sure if it does it for other gears but haven’t noticed any in first or higher.
Obviously a new engine shouldn’t be consuming as much oil as this is. I really don’t know where to start looking for or for what reason it would be pushing oil out from the valve cover. If anyone has run into this issue or has any advice it would be greatly appreciated. At a complete loss and pretty disappointed this is the result of my first rebuild.
