TDI_G
Note to self, buy the Garrett VNT17 when it is time to replace turbo.7k miles and they wouldn't warranty it? That's a crock of ****.
Snapped shafts are pretty common with BW turbos. Used to happen all the time with the KP39s.Ya I loved the turbo too up until about 6 months ago and 7k miles after I put it in the shaft snapped. Oil lines checked out OK along with the oil pump and everything else on the motor. Was running about 18-20lbs of boost max with the turbo when it let go. Apparently it must of had a boost surge and snapped as I was cruising down the interstate according to the folks at kerma so they don't cover that under the warranty. Since then I rebuilt the stock turbo and been running the same amount of boost for the last 6 months with no issues so far. If and when the vnt 15 let's go again I think I'd go with vnt 17 turbo next
I agree that quality oil is a must and warmup/cool down cycles should be compulsory to aid life of the turbo. I just think triple K turbos (BW) get a bad rep. My 1.8t raddo had the standard K04-20 on it and even though i completely abused it for 2 and half years It never once gave me a single problem. The journal still feels tightish for a 14 year old turbo. Id say its down to way you warm it up/ cool down
Here's my boost guage on the 1.8t. not excatly gentle on the turbo
most people, including myself, have not "primed" their turdos with oil prior to running and have never had any problems "manifesting" themselves many miles laterOil quality a must. Also 18 to 20 PSI is pretty high boost for a BW turbo in my opinion. BW makes a good turbo, but the Garrett in my opinion is better. I have a KPO II on my 1.8 gasser Beetle, but it only puts out about 8 PSI of boost. Good turbo. At lets say 75 MPH that much PSI unless your accelerating with your foot pushing on the accelerator pedal is pretty high. Also you must prime the turbo at installation before initial start up or damage can occur even slight and this will manifest itself later down the road.
a 5 minute turdo shutdown is ridiculous. if i've just pulled off the highway to a rest stop speeding like an absolute maniac, then i'll idle for a minute. but other than that, there is absolutely no point. and yes, i have EGT gauges mounted properly...But I do agree a five minute idle before engine shut down helps. I know that most U.S. military vehicles this is standard procedures. I agree pampering your turbo is good, they last for that 500,000 miles.
also, the s7 is advertised as "150hp" which is certainly more than 20psi lol...
Vcds verified 2 bar, but tapers off to 23-24 psi at upper rpms on 102 octane. It's the spikes I was worried about initially, the turbo kicks in quite savagely.always ran liqui moly 5w40 since I got engine. I don't usually let my engine idle, I find that just heat-soaks the engine. Just drive lot slower after a heavy boosting session for minute or two depending on heat to allow coolant pump to shift the coolant around bit quicker, close to where im going to finish driving. Then 10 second idle, turn off. Ive adapted this for my tdi but it shouldn't see nowhere near as much heat as my 1.8t did
Mine was near the limit of a standard 1.8t, 294 hp and 302 lbs/ft and I used a mk3 diesel gearbox to spread the torque out a little wider.it was the most fun ive ever had for $3500 for engine conversion, maybe next time it I'll build a diesel raddo. Think there's a few guys on here that have built one.
Im in the forces and rebuild diesel engines day in, day out and inspect them. Obviously the tank engines are bigger than my jetta but they are easier to work on.
I used to work on vertically opposed 2 stroke diesels that could run on nearly anything that burned.2 crankshafts and a pain in the a$$ to time injection pump.
Anyway on topic, I was thinking about looking at getting a s7 turbo but ill think ill save up for the vnt 17 if they're offering a verbal warranty on a turbo
Originally when the turbo went out I called Kerma and talked to them about a the warranty on the turbo and they said the only way to warranty the turbo would be able to prove 100% without a doubt that the turbo failed because of a manufacturing defect which is hard to do once the shaft snaps and the fins are damaged so bad it hard to prove 100%. I went on to ask how many turbos they have warrantied in the past and I was told no turbo has been warrantied. After putting the post up on here about the turbo failure they have called me to try to retract there staytment about never giving a warranty on there turbo and now are all of the sudden interested in helping me out. Only bad thing is since the turbo failure and being told there was nothing they could do for me I have since given away the housings of the turbo to contribute to someone else's homemade motorcycle turbo project. I did have the oil lines checked and the rest of the motor gone through to see if lack of oil flow or return line being blocked could of contributed to the turbo failure and everything checked out OK. I'll keep everyone informed on what comes out of this situation.
Nope. The agreed highest output on standard internals is around 320 lb/ft mark on the standard rods.It's the torque that bends the rods and they're the first to go. I believe someone has found the limit of a 1.8t crank at around 900-1000 hp. mine started life as a 225hp out of a tt so it has the k04-20 standard
While I'm not saying it's a bad idea. I have never in my 10+ years of current and ongoing service seen one of these signs in any military vehicle I've driven. HEMTT, HMMWV, FMTV, etc...I was referring to U.S. military diesel vehicles. They actually have a plastic sign affixed to the dash that indicates that the driver has to wait five minuets before shut down to allow the turbo to cool. This was on the old 2.5 ton multi fuel trucks. Commonly referred to as duce and a half with the Continental or White manufactured engines. It is standard operating procedure to prime a new or even used turbo after a fresh install. To each his own as far as I'm concerned I'll prime mine. It's not hard taking a funnel and your favorite brand of engine oil and putting it down the turbo oil intake line hole.
My Army driver licenses have expired years ago. The old A3 are out of service. The 2 and a half tons were replaced with a cab over 2 and a 1/2 ton LTC. I've never driven one of these. I remember having to take it easy on the axles as far as taking ditches and off road obstacles. The A3 was upgraded in the late 80's with an automatic transmission. I believe the White tri fuels six cylinders produced about 135 HP there were two main engines used the White and Continentals. The old two and a half tons were replaced in the early 2000's with a LTC I believe. I still do stuff with the Army NG, but don't operate any vehicles, I have a chance to get licensed again HUM VEE and LTC. I'm not a driver, but in the early 80's I was licensed for the two and a half ton and jeep. OLD SCHOOL??? So your right and I won't contest it on the newer ones.While I'm not saying it's a bad idea. I have never in my 10+ years of current and ongoing service seen one of these signs in any military vehicle I've driven. HEMTT, HMMWV, FMTV, etc...
Good to know...won't be buying a turbo from Kerma in the future and won't be buying an S7 either.
My Borg Warner S7 lasted 850 miles. Installed it, along with the DLC injectors, oil line, 3bar map that they said I needed, got in the car the next day, drove it from Tampa FL to Winston Salem NC. Got 50 mpg, cruise set on 80mph mostly flat ground boost was around 4 to 7 psi just like my old vnt 17. Made it to Dads late last night, got up this morning, started the car to crank up the air con to cool it down, after running about 10 seconds I heard a nasty clatter-chatter noise. I revved up the engine a little and instantly knew what it was. Turbo shaft had snapped. Now how in the heck can that happen with a great break-in period of an 11 hour steady 75-80 mph mostly flat ground cruise. Fresh rotella syn oil, filter, just ran perfect the entire trip. I was pleased with it. I am going to see what they have to say about warranty, but if they try to tell me like whats stated in their website that a qualified person needs to install it, well I will fight that one. I have an engineering degree in aircraft turbine engines and worked in that field many years back along with working on VW and MB turbo diesels my entire life. I think I am qualified. I'm curious as to what they are going to say to get out of replacing it. $1000 for 850 miles is harsh.
