Hello, recently I got 2005 A6 with 3.0TDI engine and 6 speed automatic transmission. This is my first auto car and I am concerned about transmission. I wonder if it is normal for auto to hold higher rpm until speed catches up and then rpms drop by like 200-400 rpm in same gear. For example when going a little bit more throttle than normal it will hold like 2600rpm until speed increases then it drops rpm and continues in same gear. After it switches to 3rd gear same happens it hold previous gear rpm until sufficient speed. This does not happen with Sport mode or Manual
I am used to manual and this feels super weird. Transmission is smooth no jerks or anything. I do have plans to change fluid as I am not sure when it was done last time
