Lug_Nut
- Joined
- Jun 20, 1998
- Location
- Sterling, Massachusetts. USA
- TDI
- idi: 1988 Bolens DGT1700H, the other oil burner: 1967 Saab Sonett II two stroke
Spent about 20 minutes yesterday draining the gasoline from the fuel tank.
An hour and a half tonight disconnecting the drive axles from the transmission, disconnecting the three shifter linkages, and disconnecting the two pendulum mounts. I also pulled (actually sawz-all-ed) the cat converter out.
Did I mention that the Cabrio is a 1995? Did you know that cat converters <edit: for diesels> weren't required until 1996?
Depending on when the weather co-operates I'll undo the other three motor mounts and then I'm ready to pull the 2.sl0.
Cost: $3503
Time: 23 hours
Cost: $3503
Time: 23 hours
