CantWrite
- Joined
- Jun 8, 2021
- Location
- Placerville CO
- TDI
- 2005 Passat Wagon (BHW/5-spd conv, 03T). I keep in touch with the (2) ALH's I sold.
Hello All,
I have been a long time lurker and gave up my ALH(s) after compromising with the wife and realized I have just dove into the shallow end of the kiddie pool. (I am 6'5" and the kids are getting taller. I literally removed the seat bottom out of my '03 Jetta Wagon to fit the kids.)
I currently have the following issues/faults and would appreciate some help, either pointing to threads I missed or "guiding" my learning. (I saved the scans) Vehicle: 2005 Passat TDI Wagon, 5-spd swapped (03T).
What I know about the swap:
- Address-1: P0672 (GP#2) Electrical Fault. (my plan here is to continue searching and reading)
- Temp Gauge on instrument cluster not working. Off of memory, I went to OBD-II > Mode 1 "Read Data" > Block 3 I believe to see what the computer was seeing for engine temperature with the vehicle running. It was mostly 0*C and sometimes populating with actual current temp, or what I believed to be.
- Address-3: 01435 - Brake Pressure Sensor 1 (G201). I hear a faint hissing sound, almost like speaker static above the fuel pedal. Goes away when I step on the brake and then will return. Shutting the car down I can hear it for a few seconds and then the brake pedal is hard. After reading, this sounds like the bladder in the booster is going bad.
- Emissions Workshop pops up intermittently. I am not sure if this ties into the 2 above, but I do notice that my EGR components are oily compared to the videos/pictures I have seen of others. (I searched and read, much more needed, but I seem not to have any of the codes that others are having.) Does not seem down on power
- I noticed oil on the bottom of the oil cooler, upon further inspection and after driving it for the first time (15 miles), it appears the oil filter cap is cracked where the hex head meets the shoulder/flange that butts up against the aluminum housing. I see old oil stains running down the aluminum housing.
- 03T trans was used (good/bad/meh?), although i cannot find much info about this trans, I think its from B5 Passats in Europe, I could only come up with one descent result from google and it talked about right hand drive units with this trans in England.....
- Spoke with the guy who did the swap, he believes RC1 Tune, original cam, he did not do a BSM delete, rather he replaced the chain, tensioner, key, and sprockets. He mentioned he rode in a B5 that was deleted and he did not like the additional vibrations. Since I shorted myself, I guess I will just drive it until it starts making the tell-tale chain noise. Timing Belt, Manual swap done at 150k, now at 187k.
