Levi wisti
I have been having this problem where my tdi would suddenly lose power and I would get a p0087 low fuel rail pressure code. I replaced the fuel metering valve with a darkside developments upgraded one and after I did that it started throwing the same code and going into limp mode every single time I floored it. I then replaced the fuel pressure regulator on the fuel rail and it caused it to go into limp mode every time I try to accelerate at all. I checked the fuel filter and the hpfp screen and couldn’t see any signs of metal shavings so I am hesitant to think it is the hpfp going out. Anyone else have this problem or have any advice on how I can fix this.
