Your particular variant of EA288 does not have VVT then, there are several that don't.I wish you had made photo instruction.In dan's video, the place where vvt is placed, my engine is eqiped with flat black cover. And some say that if you pull vvt valve out, the engine needs to be adapted with vcds as it may not even start up.
AbsolutelyBut the north american EA288 in the 2015 passat and golf do have it correct?
Incorrect, when i use the SS button the long crack appears(i have trouble with turning on the car). When i dont use the button everything is ok.@5N2
If I get it right. Before you turn off the engine you turn on SS button? Am I right? So you drive around with SS button on and you do nnot suffer from long crank, right? But if it is turned off before the engine is off long crank appears? I am trying to be precise as long crank appeared around the preiod when I had my SS disabled via VCDS.
A whack with dead blow/hammer and appropriate chisel through the window of the accessory bracket works just fine too.Use this puller from O'Reilly's (not the typical 3 jaws):
So is it safe to say timing of the HPFP may factor into it during TB jobs and locking down the HPFP should be in order?Update: after changing the high pressure fuel pump for another CP4 (new), and topping off the battery, the car now starts perfectly every time.
Also, some weird hiccup that used to happen like 2 blocks away from my house after the 1st start of the day, that is also gone!
I can do a timing belt confidently and quick on these CRUA/CVCA...so much practice
Now the plan for the Passat is to properly time the HPFP and see if that solves the issue. If not, then I will shop for another new CP4 or even perhaps a CP3 retrofit.
Yes, I do think HPFP timing needs to be close, as the CR TB guide says it should be, you should be able to see the hole after rotating the engine and relocking crank and cam. I will be reporting back with my Passat, as that pump is not timed right now at all.So is it safe to say timing of the HPFP may factor into it during TB jobs and locking down the HPFP should be in order?
If you are replacing CP4 for CP4, do you suspect issues with the long starts are due to a "warn out" CP4, vs completely failed units seen before?
Yes...yes, you should.Perhaps I should make a gen3 CR specific guide for TB changes.
Interesting. I'll try to check that myself.After replacing the battery, the problem still occurred. I discovered that when I don't turn off the start stop button, there is no problem with long crank, and if I use it, the problem reappears.
