powerram250
On the cam sprocket I've loosened the little torx screw with the cam lock engaged but the sprocket will not "free spin" within range of torx screw groove. Is mine just stuck or is that it?
They did seem to be in a hurry. Gonna watch your posted video now.Draining coolant from the Charge air circuit is completely unnecessary and not doing anything to limit what comes out when you pull the water pump. Also, don't need to undo the entire engine mount like that. Bracket can fit out the bottom
Belt interval is 130k, not 120k
They didn't loosen the cam sprocket either when tensioning. When spinning the crank two turns, you should be able to re-pin the sprocket. He uses a mirror and says, "you'll never get it to fit"....dude, wth! There's a lot wrong in this video.
Get the erWin manual and follow directions.
This is CJAA, so slightly different cam sprocket but same concept.
"Inspecting" the belt is a lot like inspecting a light bulb. Can you tell anything about its remaining service life? Nope. That is why there is an interval.
The CVCA/CRUA belts are different than the CBEA/CJAA, not drastically, but enough that different tools are required.
I'm replacing an engine on a 2015 Passat currently, because the owner tried a M&P, and now it has bent valves. And Jesus H-effing Christ this engine is, BY FAR, the most overly complicated mess of cooling hoses, tubes, pipes, and nonsense I have ever worked on... and I've done turbochargers on biturbo Audis and crazy stuff like that. The only saving grace is that the engine/transmission are fairly straightforward and easy to remove. But I've been working on this since 5am this morning AFTER it was out, just stripping the bits down to transfer over to the replacement engine. I bet there is close to 100 constant tension clamps on this engine. And the poor porter, every time he turns around, I made another coolant puddle because between the two EGR systems, the two electric water pumps, the two thermostats, the two radiators, the coolant going through the intake manifold, and all the little vent tubes and hoses, there is a LOT of hidden places for the stuff to hang out.
My next engine replacement is an ALH.... that will seem like a vacation after this mess. Sheesh....
i have the repair manual, give me an email and i will send it over if the size permits
Do you still have the repair manual?
--Unfamiliar with erWin - what exactly would I need to download that would cover the Timing Belt replacement?You can always go to the erWin page online and pay the $35 one day fee and download everything you want.
https://erwin.vw.com/erwin/showOrderFlatrate.do
Thanks PLC.This ^^^^^
I spent a couple of hours downloading everything they had for my car. It's the complete troubleshooting and service manual. Mechanical and electrical, including schematics.
You take away a point of potential failure. I've never put a single replacement variable pump back on any of the ones I've done.What happen if you use the non-variable?
Most go with the non-variable cause cheaper and advantage OilHammer mentioned above.Does anyone know if you have to replace the Coolant pump with the variable pump?
Thanks, Derry
