I do, because it is super easy and makes the transmission come out without any trouble.
I take the whole shebang down, steering rack and all.
Center the steering wheel, remove the lower cover on the steering shaft down low on the firewall/floor, then remove the pinch bolt from the coupling, slide the coupling up and off the pinion. Only goes on one way, no need to mark anything. DO NOT allow the steering wheel to turn now that it is loose!
Lift the car up, remove both front wheels.
Working under hood: remove air cleaner, battery, battery tray
Remove steering harness from fusebox, ground wire, and control connector (it is the harness running through the holder furthest to the inside of the car.... you'll see it). Roll the harness up and shove it down below the master cylinder area (it will come out with the assembly).
Under car: remove upper sway bar links from struts, remove outer tie rod nuts from carrier and pop them loose, remove roll mount attachment bolts from bottom of gearbox (the mount will come out with the assembly), remove exhaust hanger bolts from subframe, remove nuts from ball joint plate studs from each control arm (3 per side).
Now all you have to do is remove the six big bolts from the subframe to body, one on each side above the control arm area, four across the back (keep track of where they came from, as some cars use different lengths in different spots).
Now the WHOLE assembly (subframe, steering rack, control arms, sway bar and links) will come straight down and out of the car.
Now you have loads of room to R&R the transmission (which is cake easy on the DSG... no torque converter fasteners!).
Note: you can just unbolt each axle from the gearbox, and swing and turn the struts with the outer joint still attached towards the rear of the car and tie them up out of the way... no need to totally remove them.
Also: there is a bellhouse bolt inside the starter area, accessible after the starter is removed.
