Logdog
- Joined
- Apr 6, 2008
- Location
- Sandy, Oregon
- TDI
- None at this time, but I'm putting a TDI and Toyota 5 speed into my 122 Volvo Wagon.
Just another idea
If you're looking for a 2wd alternative when using a VW diesel, check out a Volvo 240 series car with a six cylinder diesel. Volvo used the same basic VW motor in the six cylinder variation as the four cylinder variety. They used a Volvo M47 four speed with overdrive. These should bolt right up without an adapter and they could be run through a divorced transfer case.
Back to Corvette's original thread, check out buying a front clip out of Japan for a Toyota Surf. I found that you could get the entire front half of the truck for about $4,000.00. This gives you not only a turbo'ed 3 liter four cylinder, but the transmission, transfer case and front suspension plus the cooling system and all the wiring. The motors come in either a mechanical version or electronic injection. By the time you sell all the parts you don't need, the cost of the engine is quite low. This engine makes good horsepower and torque; far better than a VW will. Torque will win the day in the Vette given its weight.
