antoniu200
Hi,
I am looking into swapping the factory-installed SMF in my mk7 Golf 1.6 TDI DDYA engine, RTD MQ250 (0A4) 5-speed transmission with a DMF from the mk7 Golf with the same engine, but 6-speed manual gearbox (02S) (there is none for my model).
Reading all over the internet about this transmission, I understand the outer case is very similar between these two models, something that you confirm:
Has anybody here tried this (or the other way around) before?
Thanks for the advice!
Now, my question is, does this apply the other way around: i.e. the 5-speeds get to use the higher quality clutch and flywheels from the 6-speed platform MQ250?[...] an MQ250 02S, which is effectively a 0A4 5 speed with another gear added to it.
The 0A4 is just an evolution of the 02J, which is itself is a mild evolution of the older 02A that dates back to the late 80s with the first Corrados. 02A/02J/0A4 "MQ250" gearboxes are about as close to Lego interchangeability as it gets for their internal parts for a design that dates back close to 35 years at this point.
This is also interesting because it means you keep the same shift bracket, same axles, starter and the much more affordable clutch and flywheels that the 5 speeds use.
