Matt-98AHU
Poking around some used cars a couple months ago, I came across a 2020 Golf 1.4 TSI with a 6 speed. This was news to me as the earlier 1.4s came with a 5 speed as their optional manual transmission.
I've been looking at transmissions in the VW Parts catalog via Partslink24.com lately just to see what's available in our market. An earlier observation was made that 1.8TSI 5 speeds use some very nice gearing that would be great for a TDI as well. Same 3.39 final drive, but taller 3rd, 4th and 5th gears.
In a mk4 TDI gearbox, generally you're going to see the following:
1.36 3rd gear
0.97 4th gear
0.75 5th gear
The 1.8TSI 5 speed box has:
1.27 or so 3rd
0.87 4th
0.66 5th
That gear spacing would at least help address the big complaint about installing a taller 5th gear, but having that large drop from 4th to 5th. If you've driven up steep grades and had to slow down for slower traffic, you might appreciate more how a 0.658 5th can be too tall while the 0.97 4th is almost uncomfortably short in real specific situations like that.
So, imagine my delight and surprise when I plugin the VIN of a 6 speed manual 1.4 TSI and see what transmission code it has, then look in the parts catalog to find out that this transmission is NOT a 02Q/MQ350 with the twin pinion shafts, but it is an MQ250 02S, which is effectively a 0A4 5 speed with another gear added to it.
The 0A4 is just an evolution of the 02J, which is itself is a mild evolution of the older 02A that dates back to the late 80s with the first Corrados. 02A/02J/0A4 "MQ250" gearboxes are about as close to Lego interchangeability as it gets for their internal parts for a design that dates back close to 35 years at this point.
After looking up the 6 speed, I was pleasantly surprised at how great the gearing looks for a Mk4.
Same 3.39 final drive a Mk4 TDI uses, but has very close to identical 1st through 4th gears. 1st is actually shorter still than the stock 1st, but it won't be super noticeable.
5th gear is a smidge shorter at 0.77 va the stock 0.75, and 6th is 0.625.
I like this because it means good used parts will be a lot more readily available in North American bone yards as opposed to the 02M 6 speeds that we did not get here for TDIs in the states natively.
This is also interesting because it means you keep the same shift bracket, same axles, starter and the much more affordable clutch and flywheels that the 5 speeds use. You also aren't going to have selector failures like the MQ350/02M/02Qs are known for, not to mention the clutch hydraulics, especially the slave cylinder, are more reliable and do not require transmission removal to replace.
The only drawback aside from the amount of work to swap cases is the fact this is a "weaker" gearbox than the MQ350s. But, there also are plenty of people making a good amount of power in the 5 speeds with no real issue. So, for my purposes, this is an attractive solution.
The challenges of performing this swap: this has 0A4 casing halves, meaning no provision for a vehicle speed sensor, there is no flywheel TDC hole with pointer, which is important for ALH timing belt jobs, and two of the three shift linkage bracket bolt holes are in the wrong location.
This is why swapping into a 02J case is necessary, especially for the VSS.
The last 'gotcha' is VW changed the pinion bearing whose outer race presses into the bellhousing. One other person had already attempted this swap upon my recommendation and found that the pinion shaft itself is 1 mm larger diameter than the older 5 speeds where that bearing presses onto the end of the shaft. The bellhousing machining was also changed drastically to accept this very different outer bearing race, and itbalso uses different set of shims for setting bearing preload.
So, I will have to lathe 1 mm diameter off the short end of the pinion shaft to get the Mk4 bearing to fit so I can put all these guts into a 02J case.
EDIT: to add to the above, I also lathed 2 mm length off the end of the pinion shaft on top of the 1 mm diameter to prevent interference issues with the case where the bearing race presses into the bellhousing.
That all being said, I have obtained a couple used 02S 1.4TSI gearboxes and will be starting on it this week. Chances are good I'll be able to finish a gearbox this week, but won't be able to install it in my car for a couple more weeks.
I think I may do a video series on this. I started with one today outlining the basic premise of what I'm going to do. You can find that here:
PART 2: Teardown
PART 3: Pinion shaft disassembly
PART 4: Differential disassembly, VSS gear trial on original diff
PART 5: Installing ring gear onto Wavetrac diff, speedo gear, bearings, comparing diff bearing styles 02S/0A4 vs 02A/J
PART 6: Installing bearings and races
youtu.be
PART 7: Diff and input bearing free play checking, shimming and friction torque checking.
youtu.be
Part 8: Pinion shaft bearing preload and gear stack:
youtu.be
PART 9: Final assembly! No wait, no it's not... Mismatch between 02J case and 02S/0A4 selector fork assembly.
youtu.be
Part 10: No, seriously. Final assembly.
youtu.be
Test drive!
youtu.be
1.36 3rd gear
0.97 4th gear
0.75 5th gear
1.27 or so 3rd
0.87 4th
0.66 5th
PART 2: Teardown
- YouTube
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
- YouTube
02S 6 speed to 02J--Pinion preload and gear stack
This video, I check the pinion bearing free play, install a shim, friction torque double check, and then ended up having to go one size up on shim to get the...
02S 6 speed to 02J swap--The Home Stretch (Or is it??)
Murphy strikes back just when I thought I was on the home stretch. 02J case doesn't want to work with the 02S/0A4 selector fork assembly.
02S 6 speed into 02J--Final assembly!
After switching back to the 0A4/02S back case, resetting bearing clearances once more, it's time to do final assembly. At the very end there are two photos o...
Test drive!
02S 6 speed into Mk4 02J--Test Drive!
All back together, car has a few other unrelated upgrades I did at the same time. Super happy with how it turned out. Absolutely love the gear spacing, and l...
