Fix_Until_Broke
Co-worker took his 03 TDI to Hall a couple years ago to have the timing belt changed...Guess who helped him put a new cylinder head and all the timing belt components on when the tensioner came loose and skipped a few teeth....I took my car there once for an engine problem and the "Free Car Wash" idiot used a squeegee to "dry" my car and put a bunch of scratches in it.
Was it the timing belt tensioner or the accessory belt tensioner that "went bad"?
If it was the timing belt tensioner, you better have someone look at it who knows what they're doing (because Hall does not). You might be best off to buy a new cam/lifters/valves and replace them all as a preventative measure before a valve breaks off and then you get to buy a new engine and turbo.
If it was the accessory belt tensioner - then you can come down from Defcon 5 and relax a little.
Don't mean to get you off on the wrong foot, but don't want to see you have problems either.
