Just wanted to update this thread,
Matt your flywheel seems good so far but your customer service is lacking in some areas. I get that you're a one man show, but if you didn't have a BHW crank nor any drawings for a pilot bearing spacer, you probably shouldn't have told me that you could do it. I only went the RS4 route because its a beefy clutch and you told me you wouldn't have any issues...but honestly whatever. I'm just glad it all worked out in the end, and props for even making the part to my drawing, it was spot on.
Unfortunately the spacer I had him make was too big and I had to have one of my friends whos a machinist shave a few thousandths off here and there, but after that everything fit great!! (Matt that updated drawing I sent you is also still too big, but you never replied after that so idk if you even looked at it lol) Guess I still need to work on a) How to measure things with calipers properly, and B) learning how to compensate for the shrinkage when you print things out of PLA.
I'll have my buddy make a few more now that we have a corrected drawing, if anyone wants one.
As to the clutch. It felt really weird at first on my way home from the shop, lots of play up top in the clutch pedal and some at the bottom before it bites. When I got home tho I noticed that the play up top minimized and realized that this was a self adjusting pressure plate. So I drove around a bit today and it feels much more normal but the bite point is still a little weird feeling, like it requires more release to bite than my old one. I'm guessing I'm gonna get used to it and once everything wears in together it'll feel more normal.
Also reverse is more difficult to shift into but from talking with Mike that might be because of that seal we put in, so maybe it'll get better once that softens up a bit.
So all in all, initial thoughts are that I would recommend this setup. Ill put some miles on it and update this down the road.
What's needed for this:
Matts Flywheel
RS4 Clutch : LuK 624303300
Longer Pilot Bearing: HK1522
Seal: G15x21x3A (might not even be needed)
Bell housing spacer: 01x103551 ***Make sure it DOES NOT end with an A***
My custom pilot spacer PM Me if you want one
Hope this helps others down the road. Danke!
