AlanTDI
- Joined
- Apr 18, 2002
- TDI
- 1996 Passat wagonTDI, 02 jetta sedan, on the dark side 2017 Rav4
We may have found the cause of the wet/puddles behind fronts seats.
Note: the front carpet also damp. After pulling up front side of carpet the foam is sopping wet!
After doing the blend door, I never replaced the front passenger and rear passenger seats.
Yesterday, decided to remove plastic passenger side molding on floor, to pull carpet back.
This is what was found the floor pan around drain grommet completely rusted
Big whole.
Could splashing from under car have loaded enough water to completely saturate the front and rear floor pans?
Short of welding, which I dont have; We are thinking of doing por15 Floor pan and trunk kit treatment
Still have to check other side grommets
http://i61.photobucket.com/albums/h46/alanb814/Passat10_zps6cqioncb.jpg[/URL]
Big whole.
