watch out putting cross racks and roof racks on sunroof equipped cars
laminated
Canada
15 Sportwagen
heard from a dealer that there are racks that arent high enough and the sunroof will hit it, and bend the track and will leak. and will cost big to fix.
demagxc
Massachusetts
2015 Golf TDI SEL
I have a set of Whispbar Flushbar racks installed with a sunroof. They are NOT high enough for the sunroof to pass under if installed without slight modification. However, if you cut a piece of 1/4" silicone mat (or similar material) to fit under the base of the rear bar, the sunroof clears just fine. If you hear any rattling, you can stick a piece of padding under the bars where the sunroof has the least amount of clearance. I used the soft side of some heavy duty velcro. This has worked perfectly for over 140k miles with lots of sunroof use over the summer.
