shortysclimbin
The coupe needs a lotus style air intake on the roof and a removable roof section...
There have been several kits by various manufacturers turned back at the border, I've do your homework first before assuming it can be done.My other company factory five racing has been selling to canada for over a decade. this car...since it ius not a vehicle and is added to anexisting jetta/golf will be able to go to canada without much issue.
mark
FYI- Mark from Smyth Performance is the one who started this thread.Check this thing out: Convert your MKV TDI Jetta Golf to a mid engine sports car for 10K
http://www.autoblog.com/2010/07/29/recycling-gone-wild-turn-your-vw-jetta-tdi-into-a-smyth-perform/
I'm on the Beta list, and I plan on driving mine to every GTG I can get to. Not this year's GTG of course, cause i haven't gotten started yet...I wonder if I will see one of these because someone in our club builds one. Something tells me that it would then show up at a Ho5G GTG...
I know of 2 folks in the Boston area who are looking at this... I strongly suspect that one will be at a Ho5G GTG a year from now. I was looking at it too, like Nick, looking for a high mpg, light weight, aerodynamic vehicle. The G3F is turning out to be not as light or aerodynamic as the original concept. Original plans were to take 1000lbs off a Jetta, now they are talking of removing 800lbs or less. The clean lines are also being broken up in the name of ease of construction.I wonder if I will see one of these because someone in our club builds one. Something tells me that it would then show up at a Ho5G GTG...
Reduce-Reuse-Recycle is the tri-directive that could help us become more sustainable as a society. Soon, a kit for the G3F from Smyth Performance – a new venture by Factory Five Racing co-founder Mark Smith – will follow those guidelines, enabling you to convert a previously-enjoyed Volkswagen Jetta into something you can really look forward to driving. The finished product will be lighter, faster and burn less biodiesel than the original vehicle, offering up to 60 miles per gallon and boasting a very naughty top speed of 140 miles per hour. All for about $10,000 and less than 100 hours of labor.
It's a simple recipe. You start by procuring a TDI diesel Jetta four door sedan. Cut away about 800 lbs of metal, reusing a large chunk of the chassis, including the entire safety structure. The engine gets chipped, modded and moved from in front of the driver to behind. Add the body, seats, wheels and all the other included bits from the kit and voila! You now own a recycled VW that increases your joy of driving while reducing the amount of petroleum product you'll need to pump.
Okay, maybe we're making it sound a little easier than it actually is, but Smith is confident there is enough interest to make a go of it with a line of depositors already being formed. Despite deliveries (optimistically) planned for September, the original prototype is still under construction. The operation doesn't have an official website either – that's coming this fall – but you can follow the progress of both car and company on both Facebook and the unofficial Factory Five forum. Hit the jump for video of Mr. Smith explaining his concept and tell us what you think.
Now, here are few questions I have about this kit:
1) I sort of understand the Radiator will be kept at front end of the car, and just by adding extended radiator hoses will be able to connect to the back to mate the engine.
What about some of us want to keep the A/C? I'm not very good on A/C system for the car, all I know is there is a high (pressure) side and low (pressure) side of the closed system; and the condenser is right behind the radiator cooled by fans.
All stock heating/ A/C will be fully functional. The radiator and AC condenser will stay in the front, new lines provided, so for the A/C you will need somebody to recharge the system.
2) Will there be welding involve with the rear sub-frame? And the front windsield support frame?
Rear frame will be complete, just bolt on, no welding required for this conversion.. just cutting.
3) Will there a complete (extended) wiring harness to the new engine location? Is the battery still located at front? (I've already moved my battery to the trunk area!)
For weight balance, battery will be moved to passenger side rear, I believe somewhere between seat and engine. There will be a wiring extension harness provided with the kit.
4) what if some of us already have FMIC- larger Front Mount InterCooler on the car? Are there enough room in the new Engine compartment to fit it?
It is being designed for either a rear mounted IC or the stock location IC, I don't know about provisions for a FMIC, there has been some talk about one.
5) What if some of us already have a Lowered (1"-1.5") Front Spindles and Large aftermarket brakes and Sway-bars? Do we keep all that at front?
Or can we have discount of elimating some of the suspension (other than the new Coil-over shocks, since the new front suspension requires Coil-over rather than Struts)
The plans are for a totally new front suspension and I don't believe the stock parts will have a place to mount to. There has been talk about discounting if one wants to use their own wheel rather than what Mark is providing. So there is some flexibility.
6) Will the seat rail and shifter be at original spot or moved back?
Plan is to provide new, lower, seats that will bolt to floor. I don't think they will fit the original rails. Shifter stays in the same spot, modifications made to send cables out the back, new cables will also be provided.
7) How do you seal the rear area between the driver and the engine compartment? Will there be sheetmetal wall with sound deading materials?
Don't know yet.
8) Will the Rear-end just consist of Rear sub-frame, engine/Trans./Suspension, and body shell?
Will there be other inner fenders, body panels between the frame and the body shell to protect from weather and enviorment (road trash)?
I don't like to adding weight by picking up stuff by the rear tires. (and left there stuck to the inside of the body shell; plus isn't it better to seal for airflow/aerodynamic- some of the race car have rear diffuser to redirect airflow from the bottom of the car)
Still being worked out.
9) How will the top be latched to the body? some (2) points to the front windsield frame? and few points to the rear top engine cover? How much does the top (with rear glass) weigh? And can the top be easily handle by the driver (one person)?
Could there be a soft top made in the future? may be a bikini top like on the Jeep? (without the rear window, but some protection from rain?) Just have is latch to the windsield frame and straps to the rear?
10) Is there Prototype build and running? or when will the first running Kit be completed (estimate date)?
Prototype is still in the design/construction phase. Which is why not all your questions can be answered at this time. Beta builders will get their kits sometime this fall, production kits should be available soon after the first of the year.
Anyway, just curious.
May be I missed some from the reading, but these are some of the questions I had.
Thanks,
