greengeeker
The MK4 dashes have a place for this, I don't know where the thread is but somewhere on here is a DIY to install exactly this.midairmark said:Mark,
What be cool if you can use the newer version of the jetta dash, that has the built in mpg information that is displayed, I think that is an 04 and up? Nothing like a racecar styled daily driver that can display its efficiency.
Also, have you considered using the euro 6 speed trans? Getting the 02M in my jetta right now (DRW code), that would increase mileage a good amount!
I have been thinking about a project like this lately and glad I stumbled upon this thread.
Mark
Good point man... the car is going to weigh so little and have so much torque (I'm planning on having one of these with at least 400ft/lbs) that I think it won't matter much if it is a 5-speed with a taller ratio. If we could source a different final drive, it would theoretically be faster than bigger tires. Higher or lower unsprung weight may be noticable in such a small, lightweight car.nicklockard said:You could also just upgrade 5th gear to the 0.638 and increase tire size +1 for much cheaper and get most of the benefit of a 6 speed. That'd be my route.
YES!!!! What was I thinking? -1000lbs, engine in rear, no power steering!! I want it even more, I didn't think that was possible. PM on the way, thanks! and... twitter... I guess I will have to join. I really thought I could avoid it somehow.Power_Not_Speed said:Most of your questions are on the Twitter page, hard as it is to get through.
AFAIK the radiator and IC are in the front, the spare for now is there as well. Everything will go through the tunnel with a heat shield to separate them. Gear linkage will be by cable. The engine/subframe will bolt in, I believe Mark said with about 20 bolts. With the roof on access to dipstick and filler would be inside the cab. I think that's what he has posted.
It seems the cruise control would still work but I think I want mine without power steering.
PM me with your email if you want the pics. I have about 60 now.
You don't need to join Twitter to see his stuff, he also has moved the majority of his updates and pictures to Facebook.manual_tranny said:YES!!!! What was I thinking? -1000lbs, engine in rear, no power steering!! I want it even more, I didn't think that was possible. PM on the way, thanks! and... twitter... I guess I will have to join. I really thought I could avoid it somehow.
If all you seek is a lower cruise RPM then yes, however, the 6 speeds I'm working on will incorporate taller 1st and 2nd gears which would be the cats ass for better acceleration in a lighter car. Also in the works are stronger 3-4 gears meaning they can hold quite a bit more power. The holdup is the sourcing of parts.nicklockard said:You could also just upgrade 5th gear to the 0.638 and increase tire size +1 for much cheaper and get most of the benefit of a 6 speed. That'd be my route.
You can see the pictures and read the discussions without becoming a Facebook member.. you just can't leave comments.nicklockard said:Wow. Progressing fast. If you're not a Facebook member consider joining just to see the pics of progress. Mark's really booking.
I love Red Green! What is so shocking is that they actually seem to get that ridiculous contraption to move at the end of the episode!ymz said:Interesting thread...
Much more my speed is http://www.youtube.com/watch?v=c-Lnfpulwjc
Good luck with the project!!
Yuri
My parent's cosigned a loan for me so I could learn about cosines...manual_tranny said:I think this is evidence of cosign error as you proposed on Facebook.
