Mysticle31
I'm currently deciding the fate of my 2005 BEW Wagon with a dead auto.
I'm days away form ordering a 6 speed. There is a small chance I pivot and get a DSG from a beetle. I can't find alot of good info on the DSG electronics....some say it is power, ground, can bus and reverse lights, others say it's more complicated. You could try and talk me out of a 6 speed and into a 5 speed if you want...
I'll probably end up with the 6 speed and an VNT-17 or hybrid. I'd love 185-190HP, but if I cant get there due to factory intercooler or factory downpipe..so be it.
Questions are...
Questions are...
- LSD or not? What do you drive? How is second gear traction in the dry? Straight line, around corners? Wet? I'm pretty 50/50 on it right now, and I need to order soon.
- What should I do to the BEW head? The engine is out and I'm inspecting and resealing everything. Should I do nothing? remove the dividers? Port match? Open the pocket book and send it to Franko6 or Whitbread? Id like to keep the swirl if it's good for lower end power.
- VNT17 or Hybrid? 15? Which is best for low end spool, egts? Hybrids have a 10-15hp advantage over a 17, but have their own drawbacks.
