snoopy smiles
do you have a driver seat? if so - a photo please.
Definitely have the sending unit! I tried to use it in my sedan but it was too long. lol I'll look for the triangle.Fuel tank sending Unit? Drivers door triangle?
You got it sir. I'll dig it out of the box.I’ll take the dash cover, the sun out here is brutal.
I think I might be able to get one of those pulled out. Let me take a look and I'll get back with you.If you have the passat TDI (4cyl really) front lower cross member that holds the radiator I'm totally interested. Shipped to 85027 (Phoenix, AZ).
Thanks!
I'll put that on the list and get back to you!Interested in a passenger window regulator, all 4 door catches, and the interior ceiling trim piece near the back hatch if its tan
Thanks!
I think so... I'll try to take a look tomorrow.Do you have the B4 brake booster & clutch master bracket? If so, shipped to 85027?
Are you talking about the handle that slides the cover in and out?looking for the trim piece by the sun roof - it is plastic. Color doesn't matter. Please reply if you do or donot have one - or know where one is. thank you
Unfortunately those never last. Anytime I've tried to remove one it's just crumbled. I actually made an aluminum plate to replace mine.It is about 26 inches long (about) and 2 inches wide. It is like a handle.
This is what it looks like. Just a solid plate with a hole in the middle for a hand hold. Four small aluminum tabs go into the plastic cover above for the bolts to thread into. I'll have to buy material to make it with, but maybe some other people would be interested as well?would you be interested in making another one? You are right - it just crumbles.
Thanks... still waiting on more input, I can make several a lot cheaper than just one. lolHere's his "Does anyone want me to make these" thread
Replacement sunroof handle - possible group buy?
Somebody recently asked me if I had a replacement sunroof handle, and I said no - they all crumble to pieces when you remove them. But it reminded me, I did make a very simple handle for mine several years ago to replace the plastic that had broken off. Would anyone else be interested in...forums.tdiclub.com
I'll PM you.any engine control modules left that aren't the BK?
