I'll try to keep it simple. Some of you may recognize this from the last time I asked, but after having thought I figured out the problem, I'm back with more details.
Back-story:
I replaced the front pads and rotors a few months ago. Hawk HPS pads, Napa Premium rotors. New Ate Typ 200 brake fluid bled with a power bleeder. Rear brakes remain stock pads and rotors on mk4 aluminum calipers with mk4 hard/soft line all the way from axle beam to caliper.
Problem:
Since then, the car has pulled to the right very slightly under braking; more severe pulling with harder braking. Right front wheel has excessive brake dust. Also, the right front tire will lock up easier than the left. The tires are all new-ish and are definitely not the problem.
Inspection:
The outside of the right front rotor has very little wear, while the inside of the rotor is worn down pretty far for its age. The inside pad on the right side is also worn down severely while the outside pad has little use. Left front pads/rotor have even, normal wear.
Solution (attempt):
I replaced the right front caliper with a Napa reman'd "semi-loaded" caliper that comes with a new caliper carrier and therefore new slide pins and boots. Re-bled the brakes with the power bleeder.
I have not yet replaced the pads and rotors (again ). I want to make sure the car brakes evenly before putting new wearables on and potentially ruining them as well.
Results:
Test drove the car with new caliper/carrier/pins on current pads/rotor and the same problem still exists. It might just be my imagination, but it feels like it's a little less of a difference than it used to be. By that, I mean that it still brakes harder on the right front, but more evenly than it used to. I could be totally wrong about that, though. The right front wheel will still lock first under hard enough braking.
Using my infrared thermometer gun, the front left rotor gave a reading of 230F, the right front rotor at 300F. Just for S&G, the left rear rotor was at 140F and the right rear rotor was at 130F.
Questions:
Does anybody have any idea what could be causing the uneven braking? Where should I go from here? Any suggestions are appreciated.
Back-story:
Problem:
Inspection:
Solution (attempt):
Results:
Questions:
