roadhard1960
I was replacing the rear axle bushings in my A4 today. The mounting plate bolts and the axle bolts by the bushings say replace but they are not torque to yield. They just say torque to 59 pound/feet. So if they are not tty, are they saying replace them for corrosion reasons? They all looked fine by the way as I live in a no salt area.
I need to find a decent shop to get an alignment. The tire shop said they could not adjust it as the camber and caster up front was off a wee bit suggesting a need to shift the sub-frame. They also noted the rear axle seemed to be sitting a bit cockeyed. This was after the front rebush but before the rear rebush. The rear bushings did not look that bad, at least compared to the front/rear bushings which I replaced with TT bushings.
