mackconsult
About two years ago I replaced the front wheel bearings on my wifes 95 passat wagon. Its a GLX model with a TDI transplant. Over the last few weeks the car started acting up so I jacked up the front end and sure enough there was play on the wheels. Got one side out but can't seem to get the passenger side hub/spindle assembly to come off the spline shaft.
Could they have failed so quickly because of the wrong torque value. I used 195 Ft/Lbs that I find on the forum back then. But then I found this thread.
http://forums.tdiclub.com/showthread.php?t=96672&highlight=axle+nut+torque
Here is my spline on the side I took off.
Should I be using the 66 ft/lb value? Any suggestions on how I can get this spindle/hub assembly off?
Any help much appreciated.
