Ookpic
I'm hoping someone can chime in and give me some ideas...
I have a 2002 Golf 2Dr with 298k kms. I picked up this from a family member last spring. Did a bunch of overdue maintenance like brakes, suspension, exhaust.
Here's the problem. It's tough to start after it's been sitting for a while (4-8hrs). When it does start it sputters and misses a bit and smokes but then within seconds evens out and runs like a champ. If I shut it down and restart, it fires right up. Here is a video I made before I installed the new starter.
https://www.youtube.com/watch?v=Cz9E6qBGJ6o
I talked to the previous owner and he said it was always tough in the cold. This is my second TDI, my other starts instantly. The thing is, it's been getting worse and sometimes stalls once.
Questions...
If a glowplug wasn't working, will it throw a code?
If the harness wasn't working, will it throw a code?
Things I've checked...
Timing. I plugged my VCDS in and the timing was WAY out so I adjusted the IP pulley accordingly and had it sitting perfect just under the high side of advanced on the graph consistently.
Fuel. I pulled the supply fuel line off of the filter and connected it to my hand vacuum gave one pump and fuel poured out no problem. I changed the filter anyway as well as the thermostatic control valve. I have visually verified there is no air in the fuel line after sitting for extended periods.
Starter. Car was very slow turning over when cold and having gone through this issue with my other car, I went ahead and changed the starter with a brand new Bosch.
Battery. New last year.
Questions...
