GolfGTD
I just ordered some of this stuff for the next oil change.
This is made by ELF, very popular in Europe and its fully synthetic oil with ultra low ASH levels. Its designed for extended drain intervals as well.
My first 2 oil changes were done at the dealer and both times i had green oil after the oil change...that indicates the CASTROL LL03 oil which is green, made in Germany and specifically designed for DPF Diesel applications with VW.
HAS ANYONE EVER USED IT? ANY OPINIONS OR EXPERIANCES???
The last time however i had the normal yellow color oil which was a bit disturbing, and i even asked what they used and they ensured me that the correct oil went in.
Now that oil has about 4-5k miles on it so it will be replaced with the TOTAL and we will see how things go from there. I may switch back to castrol depending on if there are any negative consequences with this stuff.
Front the website.
Synthetic Engine Oils
Quartz INEO Long Life 5W30
Formerly Quartz INEO 504/507
Quartz INEO Long Life possesses the most current specifications and is known as a new generation oil throughout Europe. It is especially adapted to German diesel technology although it can be used on gasoline engines as well. It has been specially approved by Volkswagen, Audi, Mercedes-Benz and BMW.
Quartz INEO Long Life was developed using TOTAL’s advanced low SAP Technology to increase the longevity of the DPF and provide extended drain intervals while being environmentally friendly.
Visit www.Total-TechSpecs.com for current Material Safety Data Sheets and Product Data Sheets.
Front the website.
