Do ignition system need to develope 19,000 PSI? ahhh no..
A gasoline engine is simple, throttle body opens allowing air to enter at a controlled rate, the ECU senses the volume of air and mixes 1 part of gas for every 14 parts of air, the gas mixes around a bit with the air as it makes it's way past the valves, the engine sucks it in compresses it a bit, an electronic signal moving at the speed of light fires a spark and boom you have ignition.
A diesel process is a bit easier and a bit more complex, I suppose it's better to say that you can't compare the two.
A diesel has no throttle body, therefore it is always sucking in all the air it can all the time. To better that one more we are going to add a turbo to really ram the air into the intake. Now we have a pump that is precisely timed in relation to the crankshaft. As the air is rammed into the cylinder it fills with a massive volume of air and is then compressed at ratios that boggle the mind. most new diesels are around 18:1 compression ratios, and some older ones go as high as 24:1. The reason is when you compress air it heats. We are going to do one better we are going to take pressurized air (around 17psi) and comress it in a cylinder with a 19.5:1 comression ratio, can you say HOT? Well because the crank is only at TDC for a very short period of time we need to act quickly to take advantage of the highly compressed air at TDC and to allow the slow burning diesel fuel enough time to burn to reduce emissions. Because there is no spark to ignite the fuel we have to rely entirely on the high temperature air in the cylinder to act as our spark plug. We cannot just spray in the fuel before TDC because as the piston compresses the fuel will start to burn too early and push the piston in the wrong direction. If we spray it in too late igniton may not occur at all. I think it's safe to say that the window of ideal injection time occurs from 20degrees before TDC and 5 degrees after TDC.
What controls Diesel RPM? Well, you need to think of a blow torch. Increase the amount of fuel to the flame and what happens? the flame gets bigger. Decrease it and the flame get's smaller. If you increase the fuel too high you get soot because the there is not enough air around the flame to burn all the fuel your dumping in. If you lower the fuel too much the flame goes out.
A diesel is very similar. We add just enough fuel to make the engine run at the rpm we want. If the engine runs faster we take away the fuel, if it runs too slow we add fuel, just like the blow torch we only add what we need.
With that in mind since we are only adding just enough fuel, we need to inject this fuel within a very short peiod of time. Since this period of time is so small given the rpm of the engine we need to be very accurate to ensure that the fuel is injected at the perfect time.
Because we need to deliver a substantial quantity of fuel in a very short period of time the fuel must be pressurized at very high pressures to get it all into the cylinder for combustion to occur at the correct time. This means we need to have pressures anywhere from 14,000-29,000 PSI and keep it in perfect time with the rotation of the crankshaft. In order to do this VW uses a special heavily reinforced belt that has teeth to keep the pump and cam in perfect time with the crankshaft. Other manufacturers use push rods, gears, chains or even the upcoming PD sytem that has no pump at all but rather injector pumps driven off of the camshft rather than an additional pump.
The timing belt is a very accurate and reliable method of running a camshaft and injection pump. The belt does not wear out the pulleys, it lasts a long time, it does not require lubtication, it's quiet, light, simple, and inexpensive.
The question keeps popping up why the belt failures? simple mechanic error! You just don't throw a belt on a car and send it on it's way. There are small adjustments that must be made when installing a different belt, notice I said different? Yes even though it is new the fact remains that there are now two belts alike. So when installing the new belt youneed to reset the cam so that it is in perfect time with the crank, and readjust the injection timing. What happens is because of the low experience levels of most mechanics with timing belts they do not understand or know how to identify some of the catastrophic pitfalls that lie within the timing belt setup.
Alignment and tension are everything with a rubber timing belt. If the belt is too loose it skips, too tight it stretches, if it's not aligned properly it shaves itself too bits! As proof of the durability of a belt I have seen belts with over 116,000 miles and that was on a TDI! it was not the prettiest belt but it hung in there.
The belt issue is blown out of proportion in my opinion. I see why VW did it this way and there are good reasons. I know other manufacturers do things other ways but there engines are all years behind the VW diesels in technology and power per liter.
Hope this helps clarify, if not my hands are too tired to type anymore....
DB
A diesel is
