roder
I am seeing actuals at 190F, ~900rpms of ~860mbar when requested is 999mbar. Is that the expected deviation you were referencing?For a vnt15, during the test, you should see a decent deviation in boost shown in VCDS, something like 100mbar, i forget exactly. The larger the turbo, the smaller the deviation as 900rpm and ~4mg of fuel simply cannot spin the large compressor enough to create boost - one might even see boost values less than current barometric.
I just completed cleaning the exhaust side of the OE VNT15 turbo vanes, upgraded to a VNT17 cold side compressor (from xmanturbos). I upgrades to a Darkside FMIC, and a Profidiesel 2.5 de-catted turbo-back exhaust. I thoroughly cleaned the EGR and intake manifold. I deleted the EGR, but left tghe ASV operational. I also added a 3mbar MAF sensor, for future tuning.
I tested the N75 output and was getting about 17hg at 24.5% charge pressure. When I did the charge pressure control test, it was as expected for an ALH - 24hg @ 0% and 0hg at 100%. When I tested vac supply by the pump, it fluttered rapidly between 18hg-21hg. I added a video.
I haven't road tested yet, and haven't gotten any under boost codes or limp mode, and I haven't heard any sucking or leaking sounds. I used hairspray and clamped hard on the IC plumbing.
Should I be concerned about the difference in requested mbar vs actuals?
