greengeeker
Cooling System: Part 1
The Ranger cooling system uses a mechanically driven fan, massive fan shroud and a viscous clutch to slip based on temperature. The problem with this type of a system is 1) It only has a limited amount of slip so even when you need zero fan airflow it is spinning and consuming power 2) When cold the viscosity of the clutch fluid is high causing basically max fan RPM until the fluid heats up. 3) blah blah blah....the system sucks.
Now that I've eliminated the belt driven fan I'm left with several different options:
So here is a New Beetle TDI cooling pack (condensor, radiator, fan panel with two fans):
I've wrapped it in cardboard to protect it during the many intalls and removals but also to provide spacing while making my mounts. In the picture below you can see the VW mounts that would normally slide into a molded slot in the header panel:
My plan is to reverse the direction of these isolators and fabricate some brackets that will bolt to the Ranger header panel. Before I can do that I need to do some trimming of the Ranger rad mounts, some brackets and other minor adjustments with a cutoff wheel to provide the space for the wider VW cooling pack. I also needed to remove a wiring chase that ran right above the radiator and will zip tie it in some convoluted sheathing a few inches higher.
Here is the driver's side showing where I needed to clearance for the condenser line:
I should also mention that the only vw cooling pack that will fit in this location (under header panel and above the frame rail) is the New Beetle cooling pack! Per ETKA it doesn't matter what engine or transmission - the radiator and condensor for all New Beetles are all 650mm x 380mm. The difference will be in the cooling fans/motors which you can simply swap out with TDI ones. I made the mistake of purchasing an AWP (1.8T) automatic Jeta cooling pack without doing the research and found it was much too big to fit => 650mm x 420mm. So if you're doing this swap get yourself a NB cooling pack as any Jetta or Golf radiator, regardless of motor, is going to be too tall.
Here is the NB cooling pack sitting in the Ranger with the flipped isolators and brackets:
And where the mounting bolts are accessed on the front side of the header panel (just look for the 4 shiny spots...ok ok I was a little generous when I said it was rust free
I would really appreciate some help from the members on my top radiator connection. As far as I can tell all of the mk4 chassis radiators have a 45deg angle built into it. Does anyone know of a VW application where it is straight and would fit this radiator? It's not the end of the world but it would clean up my radiator lines if I don't have to deal with a jog due to this.
- Ford Rad, Ford condensor, aftermarket fans, aftermarket fan controller, FMIC mounted in front of everything
- Ford Rad, Ford condensor, Taurus electric fan(s), aftermarket fan controller, FMIC mounted in front of everything
- Ford Rad, Ford condensor, VW fan panel, VW fan controller, FMIC mounted in front of everything
- VW Rad, VW condensor, VW fan panel, VW fan controller, FMIC below everything (I'll explain later)
