OK. I got it all sorted out.
I purchased the Nitrous Express 15956 regulator which is a modified Holley 12-803 (single inlet, dual outlet, 4.5-9psi operating range) with an added bypass port in the inlet AND a fuel pressure gauge. This small fitting accepts a jet that bleeds off pressure/flow so the pump isn't dead headed into the regulator. Once assembled the fitting and jet are an AN-3 fitting. I wish they had said this somewhere in their wesite! They simply state it is a D-3 outlet which doesn't mean anything to me...maybe this is normal lingo in the nitrous/aftermarket crowds.
For future reference this kit comes with:
- Regulator
- Mounting bracket
- Bypass fitting
- Bypass jet
- 1/8NPT - 3/8NPT reducer
- Fuel pressure gauge
I had to purchase:
- AN-3 to 1/8NPT 90deg adapter. I would have prefered to go up to a 1/4NPT or higher but 1/8NPT was all I could find for adapters from AN-3. For my install location I also chose to go with the 90deg turn. I put together a few different combinations of adapters and this ended up being the cheapest at $16.
- 1/8NPT - 5/16" barb (not pictured)
- M6x1.00, 12mm long bolts and washer (x2) and tapped the holes to receive them
- 3/8NPT - 3/8" barb adapter (x2). Again, I would have prefered 5/16" barb but was limited by the selection at my FLAPS. I can get a 5/16" line over these barbs so I'm going with it.
Ok, you may now return to Toyota-TDI-awesomeness.
