my 2002 jetta has been giving me trouble, i purchased this vehicle in early june so as the cold weather is now in season, i am now starting to learn the cars problems, the car was hardly cranking and i could hear my start grinding and spinning, i also could not hold my key turned and continue to fire the car as it would cause a grinding sound. so first thing i did was test my battery with a multimeter, 12.3v car off, 14.34 car running, 9.7v when trying to start the car. I confirmed that my battery is okay as well by taking it to get tested and it passed rated for 790cca battery is also from 2018 so not to old. okay battery seems to check out?, i checked the grounds and all the terminals for corrosion & cleaned the lugs with sand paper back to shiny copper, but this didnt help, i ordered a starter & glowplugs from fcp and installed it seemed like it fixed the problem for about a day, following day trying to leave work car wouldn't start it was hardly cranking until tried boosting it off a co workers car and nothing, called CAA and they showed up with a van and 2 battery packs and they couldnt get my car started... came back later and eventually got the car home, next day i tried starting it with another battery from my newer tdi and nothing same thing it wouldnt crank, tracing all my steps after installing the starter confirming everything was good, i noticed a wire was loose on the 4 pin connector that runs to the alternator, i cut the connector off and made solid connections of the wires. car fired up after and it lasted for about 2 days, before getting stuck again, very slow cranking and no pops or nothing i eventually got it running after a boost. so im pretty lost i got the battery tested already but i will do it again to make sure? any thoughts
Glow plugs and starter ordered from fcp euro
