Diesel Addict said:
This kind of flies in the face of the notion that some members here have embraced that oils in commercial applications have an easier life than those in light-duty applications such as our TDI's, doesn't it?
It depends on what type of vehicle is doing the commercial service. Stop and go driving is going to affect a gas-engined taxi with 5 quarts of oil differently than a Cat C15 with 11 gallons.
This is a separate comparision than the old 'light duty VS. heavy duty diesel' issue as well.
The US oil and filter industry has listed 'severe service' factors for many years. Keep in mind that this is from the viewpoint of the typical US 'Big 3'
gasoline engined car. And is based on using API spec oil. Severe service as defined by the
Filter Manufacturers Council:
[FONT=Arial, Helvetica, sans-serif]
Trips of less than four miles (6 km) is the key factor in keeping most motorists in the average or "severe" category. In most owner's manuals the following are considered "severe" or average conditions:[/FONT]
- [FONT=Arial, Helvetica, sans-serif]Frequent idling for long periods of time, such as stop-and-go driving in heavy traffic. Many vehicles are subjected to this condition twice a day in commuting to major cities.[/FONT]
- [FONT=Arial, Helvetica, sans-serif]Sustained highway driving in hot weather, such as vacation travel. [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Towing a boat or trailer, carrying heavy objects on a rooftop rack. [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Driving in dusty conditions, such as over dirty or gravel roads, or where volcanic ash is blowing around. [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Prolonged operation at sub-zero temperatures. [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Driving on steep hills or mountains on a regular basis. [/FONT]
Owner/operators that I work with have different drain intervals depending on service. The long-haul 180,000 - 200,000 miles per year guys with generally medium weight loads are running 100,000-120,000 mile OCIs. The guys running heavy around town (construction trucks hauling rock and semis hauling grain at harvest time) generally run closer to 50,000 mile intervals.
AMSOIL's light diesel (pickup/SUV) standard drain recommendations are 1 year or 25,000 miles for normal service, and 1 year or 15,000 miles for severe. They have slightly different
definitions of normal and severe than the filter council and API.
Diesel Severe: Extensive idling, daily short trips less than 10miles, frequent towing, plowing, hauling or dusty-condition driving.
Gas Severe: The above plus: Turbo/supercharged engines, commercial/fleet, first and subsequent use of AMSOIL in vehicle with more than 100,000 miles.
In general, longer trips in moderate weather with an 11 gallon oil supply is good, while an overloaded 1.8T Passat with the 3.2 quart sump running petroleum oil for short trips in Srn Arizona isn't so good...
