VNT 15......back in service, after on the bench cleaning
You tell me what's sticking.......Vanes or the internal mechanism that operates the vanes.
What you see in the following photos cannot be reached using the Chemical Clean. If you say yes, then, tell me how the Chemical and Crud gets out.
Note the Vanes are there in the middle (all 9 of them). The levers that move them are on the outer circumference!
Below, nice and clean
Below is the Turbo "cartridge." You are looking at the Turbine side of the Turbo. It goes inside the housing........Vanes direct exhaust gas onto the Turbine blades....angle of the Vanes determines boost! Notice the shield immediately behind the blades of the Turbine.....that shield goes into the center hole of the housing virtually sealing off the area behind it. How does the chemical get in and out?
Below, nice and clean Turbine.........tooth brush and Dawn!
Below, nice and clean Impeller (Compressor) .......tooth brush and Dawn!
Taking the RPMs up to about 3200 to 3500 gradually at first then really press down until your Boost spikes at max will exercise the Vane operating mechanism sufficient to keep it working for many miles! Do that at least two or three times per tank of fuel. 4500 RPMs is not necessary!........
My Turbo works fine and has never been taken off nor chemical cleaned, almost 309k miles on it!
Hope this is helpful to those who want to tackle Turbo removal and bench cleaning!
