Ok. Finally got my BCM, got a vcds, here are my codes.
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
www.Ross-Tech.com
Saturday,29,April,2023,19:19:49:53046
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 3VWPL7AJ1BM650247 Mileage: 288980km-179563miles
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Sporadic communication error 1000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CJA) Labels: None
Part No SW: 03L 997 030 B HW: 03L 906 019 DA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 39035 001 1048576
VCID: 2D577F73B4DE0849F59-8078
2 Faults Found
001025 - EGR System
P0401 - 001 - Insufficient Flow
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 288954 km
Time Indication: 0
Date: 2023.04.04
Time: 12:22:12
Freeze Frame:
RPM: 1978 /min
Speed: 101.0 km/h
Voltage: 14.21 V
Load: 95.7 %
Load: 100.0 %
Mass Air / Rev.: 430.0 mg/str
Mass Air / Rev.: 435.0 mg/str
001384 - Cruise Control Switch (E45)
P0568 - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 288989 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Speed: 0.0 km/h
(no units): 255.0
(no units): 255.0
Bin. Bits: 11000000
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 052 G HW: 02E 927 770 AM
Component: GSG DSG AG6 512 9136
Revision: 05551213 Serial number: 00001205211204
Coding: 0000020
VCID: 1839BEA72B5C9DE1B6F-804D
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C492700FA880D06E892200042B70000
Shop #: WSC 00066 000 00000
VCID: 78F99E27CB1C7DE156F-802D
5 Faults Found
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 51
Mileage: 288519 km
Time Indication: 0
Date: 2023.03.31
Time: 00:01:44
Freeze Frame:
Count: 7
Count: 15
Count: 20480
Count: 128
Count: 27904
Count: 1
Count: 256
Count: 0
02214 - Tire Pressure Warning
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 179
Mileage: 247901 km
Time Indication: 0
Date: 2022.04.02
Time: 23:15:20
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 50432
Count: 0
Count: 1277
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 18
Mileage: 287259 km
Time Indication: 0
Date: 2023.03.26
Time: 00:00:40
Freeze Frame:
Count: 2
Count: 12
Count: 12800
Count: 16390
Count: 51200
Count: 0
Count: 516
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 18
Mileage: 288989 km
Time Indication: 0
Date: 2023.04.29
Time: 00:02:36
Freeze Frame:
Count: 2
Count: 12
Count: 4096
Count: 166
Count: 44800
Count: 1
Count: 767
Count: 0
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 18
Mileage: 288989 km
Time Indication: 0
Date: 2023.04.29
Time: 00:00:03
Freeze Frame:
Count: 2
Count: 12
Count: 4096
Count: 294
Count: 43776
Count: 0
Count: 512
Count: 0
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00149
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW32.rod
VCID: 75E79713D40E00894D9-8020
4 Faults Found
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 18
Mileage: 288518 km
Date: 2023.03.30
Time: 03:27:47
13701392 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 18
Mileage: 288518 km
Date: 2023.03.30
Time: 03:27:47
9481748 - High Pressure Sensor
B10AE 14 [008] - Open or Short to Ground
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 58
Mileage: 288518 km
Date: 2023.03.30
Time: 03:27:48
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 09:42:59
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 5K0 937 084 E HW: 5K0 937 084 E
Component: BCM PQ35 B 011 1035
Revision: BG011001
Coding: 2D380E1F902F3EC4008800816000004401000086535D8560648020000040
VCID: 34616A1797F45981BA7-8061
12 Faults Found
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 189
Mileage: 279782 km
Time Indication: 0
Date: 2023.02.24
Time: 00:33:25
Freeze Frame:
Term 15 On
Voltage: 14.20 V
ON
ON
OFF
OFF
OFF
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 135
Reset counter: 18
Mileage: 288518 km
Time Indication: 0
Date: 2023.03.30
Time: 02:14:41
Freeze Frame:
Term 15 Off
Voltage: 13.95 V
OFF
OFF
OFF
OFF
OFF
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 132
Reset counter: 57
Mileage: 288518 km
Time Indication: 0
Date: 2023.03.30
Time: 02:15:38
Freeze Frame:
Term 15 Off
Voltage: 15.05 V
OFF
OFF
OFF
OFF
OFF
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 17
Reset counter: 18
Mileage: 288518 km
Time Indication: 0
Date: 2023.03.30
Time: 02:15:38
Freeze Frame:
Term 15 Off
Voltage: 14.10 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 51
Mileage: 288518 km
Time Indication: 0
Date: 2023.03.30
Time: 02:15:38
Freeze Frame:
Term 15 Off
Voltage: 5.90 V
OFF
OFF
OFF
OFF
OFF
00907 - Intervention load Management
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 288938 km
Time Indication: 0
Date: 2023.04.04
Time: 10:46:03
Freeze Frame:
Term 15 On
Voltage: 10.30 V
ON
ON
OFF
OFF
ON
00927 - Terminal 30 (Right)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 1
Fault Frequency: 10
Reset counter: 11
Mileage: 288518 km
Time Indication: 0
Date: 2023.03.30
Time: 02:15:38
Freeze Frame:
Term 15 Off
Voltage: 10.95 V
OFF
OFF
OFF
OFF
OFF
01038 - Central Locking Thermal Protection
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 33
Mileage: 286112 km
Time Indication: 0
Date: 2023.03.21
Time: 11:57:14
Freeze Frame:
Term 15 Off
Voltage: 12.05 V
OFF
ON
OFF
OFF
OFF
01117 - Generator Terminal DF Load Signal
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 58
Mileage: 288521 km
Time Indication: 0
Date: 2023.03.31
Time: 00:05:36
Freeze Frame:
Term 15 On
Voltage: 9.95 V
ON
ON
OFF
OFF
OFF
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 253
Reset counter: 51
Mileage: 258865 km
Time Indication: 0
Date: 2022.08.11
Time: 21:30:35
Freeze Frame:
Term 15 On
Voltage: 13.85 V
ON
ON
OFF
OFF
OFF
01516 - Terminal 30; Left
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 51
Mileage: 288518 km
Time Indication: 0
Date: 2023.03.30
Time: 02:15:38
Freeze Frame:
Term 15 Off
Voltage: 10.70 V
OFF
OFF
OFF
OFF
OFF
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 279645 km
Time Indication: 0
Date: 2023.02.24
Time: 00:06:06
Freeze Frame:
Term 15 On
Voltage: 15.95 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel (J527) Labels: Redir Fail!
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JJB00056
Coding: 188A140000
Shop #: WSC 00066 000 00158
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76E5901FC9080B91443-8023
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H07 0013
Serial number: 0097419
Coding: 820000
6 Faults Found
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 58
Mileage: 288519 km
Date: 2023.03.31
Time: 00:01:37
117012 - Databus
U1121 00 [008] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 00:02:34
117028 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 00:02:34
136194 - Supply voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
147462 - Terminal 15
B1148 12 [008] - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 00:03:38
147464 - Terminal 15
B1148 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 18
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 971 CX HW: 5K0 920 971 CX
Component: KOMBI H20 0422
Serial number: 00000000000000
Coding: 270F01
Shop #: WSC 23312 444 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 071BEDDBBEE202192F5-8052
3 Faults Found
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 00:00:26
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 00:00:27
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 09:03:27
Address 19: CAN Gateway Labels: Redir Fail!
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 17111001201789
Coding: ED807F0600160300002002
VCID: 2E55787FB9D87351CC3-807B
6 Faults Found
00470 - Company Comfort Databus in Single Wire
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 33
Reset counter: 58
Mileage: 288989 km
Time Indication: 0
Date: 2023.04.29
Time: 06:18:23
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 18
Mileage: 288989 km
Time Indication: 0
Date: 2023.04.29
Time: 00:04:31
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Time Indication: 0
Date: 2023.04.29
Time: 00:00:25
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Time Indication: 0
Date: 2023.04.29
Time: 00:00:25
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 35
Mileage: 247676 km
Time Indication: 0
Date: 2022.04.01
Time: 18:31:18
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Time Indication: 0
Date: 2023.04.29
Time: 09:02:59
Address 1C: Position Sensing
Cannot be reached
Address 25: Immobilizer (J334) Labels: Redir Fail!
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0422
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADDB46F8DB0DF71D0B-803F
1 Fault Found
9456433 - Key
B104B 31 [009] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 18
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 42: Door Elect, Driver (J386) Labels: Redir Fail!
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001543657
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 275B8D5B5E2222190F5-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388__TSG-HL 006 1401
Serial number: 00000005193568
Coding: 000490
7 Faults Found
66048 - Motor for Front Window Regulator
B11EC 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 52
66304 - Switch for Drivers Side Window Regulator
B11F0 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 21
Mileage: 284299 km
Date: 2023.03.08
Time: 17:25:20
67330 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 25
Reset counter: 49
Mileage: 281539 km
Date: 2023.02.24
Time: 03:03:23
68098 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 00:00:27
68100 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 00:00:27
68107 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 58
Mileage: 288518 km
Date: 2023.03.30
Time: 03:27:44
68108 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 58
Mileage: 288518 km
Date: 2023.03.30
Time: 03:27:46
Address 44: Steering Assist Labels: Redir Fail!
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 316F6303A8E66CA9D11-8064
1 Fault Found
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Battery Volts: 0.0 V
PD
Temperature: -70.0°C
Count: 0
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 46: Central Conv.
Cannot be reached
Address 4F: Centr. Electr. II (J520) Labels: Redir Fail!
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H25 5603
Coding: 050B0500
VCID: 6FEBA57BBE523A59875-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
1 Fault Found
02071 - Local Databus
Freeze Frame:
Fault Priority: 1
Fault Frequency: 59
Reset counter: 56
Mileage: 259281 km
Time Indication: 0
Date: 2022.08.16
Time: 18:34:26
Address 52: Door Elect, Pass. (J387) Labels: Redir Fail!
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001509139
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 28598E67533C2D6106F-807D
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389__TSG-HR 006 1401
Serial number: 00000005295892
Coding: 000490
4 Faults Found
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 00:00:27
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 58
Mileage: 288989 km
Date: 2023.04.29
Time: 00:00:27
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 58
Mileage: 288518 km
Date: 2023.03.30
Time: 03:27:44
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 58
Mileage: 288518 km
Date: 2023.03.30
Time: 03:27:46
Address 56: Radio
Cannot be reached
