eb2143
RESOLVED, SEE BELOW
I'm troubleshooting an intermittent problem for 2 months. Occasionally the starter will not engage when the key is turned to the start position. GP light is on and everything else is normal. There is no obvious click from the starter when this happens (had my hand on the starter) so I don't think the solenoid is engaging (very tight space to verify with a MM with battery still in).Usually it will turn over and start immediately on 2nd or 3rd try, though one time was probably 10 minutes and about 15 attempted starts. Wiggling the key in the ignition seems to have no effect. The starter is a Bosch reman that 3.5 years old/45k miles.
I need to continue following this troubleshooting thread:
http://forums.tdiclub.com/showpost.php?p=1972354&postcount=5
What I have done so far: Cleaned all contacts to battery terminal, starter power terminal, grounds. No excessive corrosion on any terminals, grounds, or cables noted. The braided ground cable on the starter itself had surface corrosion but seemed sound. I failed to inspect the solenoid signal wire, so I will do that tomorrow.
My question is if anyone can interpret the following: I've never had an issue on the first start of the day when the engine is cold. It reliably will not turnover on 1st try after a long drive; so it seems to be related to heat? TIA
----EDIT found post where signal wire to solenoid had frayed and because electrical resistivity increases with temperature, that car exhibited similar temperature dependence. Hope to find wiring issue tomorrow.
