OK I replaced the MAF(needed), Replaced the return lines from the injectors(needed). Timed the IP. Then I changed the Fuel filter and bled it. Bled out the IP and then bled out the Injectors one at a time. Still the car sputters when I first start it when cold. Well it is 87 Degrees so not cold. Are there any other ideas on what makes this thing sputter on the first start? Last about 1 minute. Also I cleaned the Snow screen, not even dirty changed the Air filter(needed. I do have to say when I first opened all the injectors and turned it over I didn't see much spray at all. Then I started the car and opened them one at a time and got a lot of spray.
