millere5815
I thought I noticed something off with my car the other day when passing someone on my way home from work. Tonight I decided to replicate it. Put my car in 5th gear at 60 MPH, sits at around 1800 RPM. Put my foot down as if I was passing someone, and the RPM shot up to 2200 RPM, the dropped down slightly. I can only guess that is my clutch, which really pisses me off since I just had it installed around 16k miles ago.
Does this sound like a clutch problem to you guys? If not, what could it be?
Update: The clutch was not the problem. The slave cylinder was not working properly, causing the clutch to slip.
Update, again. 1/26/16 : got my car back about a week before. New slave and master cylinder, as well as having the clutch cleaned up by south bend. The clutch is still slipping, and getting worse.
