For that ultimate in high fidelity TDI action in 4k
You leave my Monster (TM) Injection pump harness magic gold plated oxygen free cables alone you big meanie. You'll see when I gain .2hp and .001 seconds in the 1/4 for a ripping 16 second pass.
No srsly tho. 4 real. What I have dug up from forum members here analyzing MPDS & QA signalling via scope is that this is a fairly sensitive circuit. You don't want any nonsense in it.
I am going to start with 5 wires 3 twisted for the MPDS and 2 twisted for the QA run parallel probably no pins between ECU and pump. Perhaps two more for the N108 advance solenoid. There's free pins in the ECU connectors from the factory for harvest. I have six rolls of decent enough 20 gauge hookup wire.
Bosch spec is gold plated I did read that somewhere and pretty sure the pump side is plated possibly even VW harness side. I should open it but for now it has stabilant 22a so I don't feel like breaking it ATM. (I did that a week ago and can't remember if VW side was plated)
After rewiring the 109 relay circuit off factory wiring to the fuse panel and having a car that stopped leaving me stranded when everything tested fine under load and heat i don't want these p1651 QA issues to go full retard when I am say in Colorado or middle of winter -10f.
