Had a few more questions for y'all before I continue with this process. I saw a youtube video on how to remove the injectors and it seems pretty straight forward, but didn't explain a few details that pertain to my specific issue, the video was on how to replace the injectors with new ones rather than just taking them off and re using the same ones.
1. When trying to get all the carbon out of the cylinders, should I crank the engine with the intake manifold off or on? or does it not really matter?
2. I'm assuming I'm going to have to shut the fuel pump off when doing this process so fuel doesn't squirt all over my engine, what fuse should I pull or connector do I disconnect in order to make sure fuel doesn't come out of the injector pipes?
3. Can I use the same copper crush rings when putting the injectors back on or should I buy new ones?
4. A little bit of fuel dripped out the bottom of the injector pipes where they meet the pump (only loosened the fitting just enough to pull back the pair of injector pipes enough to where they had enough clearance for the slide hammer), will this be an issue later since I might've introduced air into the pipes?
5. I've seen some differing opinions online about the answer to 4, the dude in the video I saw online left the fittings at the top loose (after re installing injectors) and cranked the engine. Fuel of course spurted out the top of each injector, then he tightened injector #1 and #4 first once he saw fuel was coming out in more of a solid stream, thus telling him that all the air has been purged out of the pipes. Then he went to #2 and #3 and did the same thing. Should I follow this same technique or just tighten them all before cranking, and let the pump purge all the air out on its own?
6. I took a few of the intake manifold bolts off yesterday (on cylinder #1 and #2) but once I got to the right side, there was something in the way of me accessing the bolts on cylinder #4, which I believe people earlier were saying was the heat shield but I could be wrong. Do I have to be worried about coolant or oil leaking when taking this part off?
p.s. this is the video I watched for the injector removal:
