Jshua
***Update***
Since it is getting to the end of the semester the projects and course work are getting piled up so I wont be going home often. I will only be able to offer parts that I have on hand and if I do end up getting more I will list them. At the first of the year I will be offering the body parts to sell.
Also this car is getting chopped up to save room on my scrap trailer. If anyone needs replacement panels for fixing a wreck or what ever else I may be able to cut it out. If you are interested PM me and we can work out a deal. It will have to be pick up only.
Link to Photobucket gallery. Its parts only and everything is for sale. I started the account just for this purpose
http://s1252.photobucket.com/user/Jshua22/slideshow/
Here is the list of stuff that I have on hand that can be sent out. If the pic is not here I can get you one
Prices are not firm just a starting point
99.5 accelerator pedal $30
99.5 CCM 1JM 907 291 C Car had crank windows power locks. $40 Shipped
ABS Pump 113K $40
ABS pump bracket $15
A/c expansion valve with cover and hardware $25 shipped
Wood bottom trim piece under HVAC controls $15
Wood Climatronic trim $15
Headlight switch $8
Manual Mirror $30
99.5 intake pipe with map sensor insert $30
In dash cup holder works has the normal scratches on face plate. $30 shipped
Crank Pulley
Intercooler to turbo pipe 99.5 $25
Monsoon Amp $20
Low mileage Cluster 113K $80 Shipped
Engine mount $15
Transmission mount $15
Driver side lighted vent $15
Coolant jug $18 shipped
ABS pump $25 shipped
Hazards switch $10 shipped
Seat rail covers for under the seat pair. $15 shipped
I also have a 3 inch MAF housing that was off a Mercedes. Volkswagen MAF sensors will bolt into it and work fine. It just does not have the holes to bolt into the air box. It would need rubber connections on both sides. Great for more volume. PM me if interested and Ill send pics.
Cup Holder $30 shipped in the US
Wood trim piece $15.00
Headlight switches ONE is sold one is available $8
Manual mirror. red does not match VW red repaint or use as it is. The mirror is in great shape. It works fine. $35
Intake pipe from a 99.5 TDI with the spot for a MAP sensor. great shape $30
Crank Pulley decent shape $20
Headlight plugs with around 6 inches of wire SOLD
Stock map sensor SOLD
Climatronic controls SOLD
ABS Pump 113K $40
Headlight switch $8
Manual Mirror $30
Crank Pulley
Monsoon Amp $20
Engine mount $15
