Side mirror blinker bulb replacement
crdouger
Michigan
99.5 & 06 jetta TDI's
Anybody know how to get the lens off my 06 driver side door mirror so I can replace the burned out light bulb. I've gently pried on it with a screwdriver, but I'm afraid I'm going to crack it. Any help or pictures would be appreciated!
nord
Southern Tier NY
All turned back to VW. Now a 2017 Hundai Tuscon. Not a single squalk in 10k miles.
That "bulb" is actually a series of LED's. They aren't likely to burn out. More likely is a broken wire in the harness where it enters the door from the car.
redbrick1
Milwaukee
2009 JSW TDI
The led's do go bad; my did at about 30K miles. I think moisture gets in and damages it. Anyway, an easy repair, see here: http://www.myturbodiesel.com/1000q/a5/turn-signal-side-mirror-replacement-jetta.htm
I bought the replacement part at the dealer (most conveinent), IIRC about $45 or 50 bucks. Good luck.
CosmicMiami
Miami
2010 Jetta Sedan-Trudy
I'm having a similar issue on my driver side mirror on a 2010 Jetta TDI. It was blinking rapidly and intermittently for awhile and now has just a couple "bulb" working. The link is a little confusing. Must I remove the mirror to access the light housing?
goosegunner
Wisconsin
Jetta, 2003, Reflex silver, 2006, DSG, white
The glass comes out, then the housing. At that point you have access to the screws to take the inner black plastic off to get access to remove the light.
Its about a 10 minute job.
gg
