Thingsfallapart
Hi,
I have a few issues that need to be addressed on my 2005 Passat Wagon It's well used at 220k miles. I've done the BSM delete with all recommended add-ons e.g. timing belt water pump etc., recently replaced struts, shocks and springs, recently replaced cv joints with high quality parts, new tires last year, brakes and rotors on the front and rear. It doesn't go through much oil. Seems to be a leak high in the engine. Possibly an intake flap weep hole.
I've put 10k on it this summer visiting family in Maine and Wisconsin. Averages 39ish mpg on the highway.
Only problem was a blown egr cooler. This was painful as it happened on my last trip to Wisconsin. I live in Maryland and was 8 hours away from home and 8 hours away from family. This post saved my bacon: Replacing EGR cooler for leak. I couldn't believe I fixed it with hardware parts AND the hardware store was only 3 miles away from me at the time.
This is the list of known issues:
I think I should:
Thanks,
Rick
- Replace EGR cooler - previously replaced 5 years ago. Darn cooler.
- Replace heater core - broken when trying to burp the heater.
- Replace intake flap
- Replace brake fluid reservoir - noticed corner of reservoir had crumbled while I was breaking the heater core
I think I should:
- Check compression
- Check cam shaft
Thanks,
Rick
