i have a fwd 6 spead manual and when in 5th or 6th gear with engine rpm under 2.5k (speed 80-100kph) and hit the accelerator i feel shaking. i was suspecting either clutch or dmf but when visited the dealer and went for test drive he said this is probably worn inner joints on a half shaft.
my only dilema with that explanation is why there is no shaking even at full throttle if you shift in 5th and 6th at higher engine rpm (above 3000). then car only accelerate hard and with no skaking.
as i understand half shafts are extensions from diff that acts as final gear ratio. and for them it does not matter which gear you use, but clutch on the other hand does feel higher torque at higher gears.
by my understanding if it is due to worn
inner joint it should shake even at lower gears and
troughout all engine rpms.
