compu_85
Gadget Guy
We've gotten a couple questions about how we put EGT on our ScanGauge II, so I'll make a quick post.
I got this information from here: http://www.scangauge.com/support/xgauges-for-cansf-vehicles/
Here is the best information to monitor on your Passat...
EGT1 (pre-turbo): This is useful for monitoring warm-up mode and temps going into the turbo. This will change very rapidly as you change the accelerator position.
TXD: 07DF0178
RXF: 054106780000
RXD: 3810
MTH: 00090032FFD8
NAM: EGT
CAT B1S1: This is useful for monitoring regeneration activity. Anything over 900F is a regen.
TXD: 07DF013C
RXF: 0441053C0000
RXD: 2810
MTH: 00090032FFD8
NAM: DPF
Boost pressure: This is useful for monitoring boost pressure. You should see 0 PSI with the ignition on and the engine off. You should see a max of 23.0 PSI on a stock tune.
TXD: 07DF0170
RXF: 054186700000
RXD: 3810 (4810 for a model year 2015)
MTH: 00910BB8FF64 (for sea level - you'll need to adjust the last 4 digits if you live at altitude in order to get to 0 PSI with the ignition on and the engine off. Also note that the baseline will change with atmospheric pressure as you change altitude.)
NAM: BST
Water Temperature: This is useful for monitoring actual water temperature
This is a normal gauge - no XGAUGE required, just cycle through the presets.
Personal note: I watch both exhaust temp sensors listed above and wait for both to be below 450F before shutting off the engine.
For information on how to program an X-Gauge, read page 38 on the Owner's Manual here:
http://www.scangauge.com/wp-content/plugins/download-monitor/download.php?id=1
Thanks,
-Jason
TXD: 07DF0178
RXF: 054106780000
RXD: 3810
MTH: 00090032FFD8
NAM: EGT
TXD: 07DF013C
RXF: 0441053C0000
RXD: 2810
MTH: 00090032FFD8
NAM: DPF
TXD: 07DF0170
RXF: 054186700000
NAM: BST
Thanks,
-Jason
