ah ok. I had it plugged in before starting it. strange quirk if that's the case.make sure the car is running with before you plug it in.
hmmm is there a trick to getting that to power up?It won't connect unless the computer is powered up.
Get in the car.hmmm is there a trick to getting that to power up?
I need someone to hold my hand through this setup lol. total amateur obviosuly.![]()
I must have a weird SG then. When I installed mine I just turned the key till all the dash lights powered up, the so called on position then plugged in the SG pushed the mode key and it went threw the connecting thing. Connected in about 20 seconds. Then did the set up.VWs don't have an accessory key position
The ScanGauge shuts off it if sees the engine isn't running. Start the car.
-J
Thanks Mate. Thought I was losing it there. I must have been a really fast button pusher when I installed it a year or so ago.It will work with KOEO (key on engine off), but it will go to sleep if you stop pressing buttons. It remains awake when it senses an RPM signal. Either way will work, just keep in mind that the ScanGauge may go to sleep if the engine isn't running and you don't press any buttons for a few seconds (20?).
Thanks for the info on this Jason, Sounded so cool I ran down to autozone and bought one. I went to X-gauge and installed the codes you have above and named them. I then pulled them up on the screen and there is no info displayed next to them. The others like water temp and fuel burn work fine. Any ideas?We've gotten a couple questions about how we put EGT on our ScanGauge II, so I'll make a quick post.
I got this information from here: http://www.scangauge.com/support/xgauges-for-cansf-vehicles/
If you scroll down in the list you'll find the section labeled "Catalyst Temp Sensors"
Instead of CTF or CTC, use EGT for the label on the units you prefer.
For information on how to program an X-Gauge, read page 38 on the Owner's Manual here:
http://www.scangauge.com/wp-content/plugins/download-monitor/download.php?id=1
Thanks,
-Jason
Did you add it to an open Xguage slot? I put it in slot one and it didn't take. Toggled over and put it in 3 and worked like a charm. I didn't have the book open and just assumed the first slot was reserved.Thanks for the info on this Jason, Sounded so cool I ran down to autozone and bought one. I went to X-gauge and installed the codes you have above and named them. I then pulled them up on the screen and there is no info displayed next to them. The others like water temp and fuel burn work fine. Any ideas?
It is still just stuck in the connecting.... and then shuts off.Get in the car.
Start the engine.
Plug in the ScanGaugeII. It will start up a few seconds later.
bummer ok. Yeah I did that. I got in started the car. Plugged the scanner into the obd2 port and it just sits there and does nothing and eventually just shuts off.Mine is a 2013 and no problems. Make sure it is un-plugged and then start the car. Plug it back in. If that does not work call their Customer Service.
I just bought my ScanGauge, so I'm not as up to speed as some others. But, if you take a look at this link, it says that you can monitor four different catalyst temps: http://www.scangauge.com/support/xgauges-for-cansf-vehicles/I'm still trying to get an answer to a question I asked a while ago. Can any of these aftermarket gauges (ScanGauge, Torque, Ultragauge) actually read VW measuring blocks, as opposed to just generic OBDII PIDs. I really want to know if any of these gauges can read all 4 EGT sensors in CR diesels. I would really like a display that shows the after DPF EGT sensor so that I can monitor DPF regenerations. I would love to be able to display the pre turbo EGT and the post DPF EGT. I know that the sensors are there, but the only way I know of to read them reliably is VCDS.
I get the impression that these gauges work only by reading generic OBDII PIDs. If this is the case, my MFD and my Kufatec E-MFA tell me almost everything these aftermarket gauges can tell me. I don't want to spend money only to be disappointed. TIA
Have Fun!
Don
