streeker02
What was he token? I must have missed thatblackchrome said:Thanks to the "token brown guy"
Thanks for all your hard work Omega!
It's the best stuff I've used. Apparently he gets it from a local shop, but you have to buy 4 of those jugs at once. Group buy?petea4 said:Hey Brandon, where did you get that dry green handcleaner stuff? Works pretty good!
Pete
HAHAHA my numbers can be known since most already know.. im not ashamed of my numbers. for those that want to know it was 199.1WHP! I couldnt buy .9 to get 200whp no matter how hard i tried because the clutch wouldnt take it! but im sure with a better clutch that ACTUALLY holds that i could produce ALOT better numbers but that will have to wait till spring Great seeing ALOT of new facesmrvermin said:Well, apparently the Dyno Day on Saturday was all screwed up and henceforth invalidated.
It appears that since I am not allowed to make 309ft torque with what I currently have, then Marchmen at 340ft torque and OmegaRenegade at 325ft torque as well as Ryan's monster pull (I'll let him decide if he wants the number made known)are all garbage as the Dyno was broken. All those runs are all for naught.
Well, maybe Ryan is smiling at this as that will let him get a new Clutch and maybe that .9hp
Ahh well, you don't have to worry, I won't be running another Dyno.
I know what I know and I need not know no more...
MrVermin
You shoulda done the "hairspray" thing, huh?VwPodRacer said:HAHAHA my numbers can be known since most already know.. im not ashamed of my numbers. for those that want to know it was 199.1WHP! I couldnt buy .9 to get 200whp no matter how hard i tried because the clutch wouldnt take it! but im sure with a better clutch that ACTUALLY holds that i could produce ALOT better numbers but that will have to wait till spring Great seeing ALOT of new faces
haha would of needed alot of it! More like I needed some stickem! No worries spring will be here soonStreet Toys said:You shoulda done the "hairspray" thing, huh?
My dyno improved 3 hp and 25 tq from the run I had earlier in the spring. I'd like to think the results came from Jeff tweaking my sharkfin antenna but I'll defer to the experts. I will dyno again next spring having finally replaced the stock exhaust by then.mrvermin said:Well, apparently the Dyno Day on Saturday was all screwed up and henceforth invalidated.
It appears that since I am not allowed to make 309ft torque with what I currently have, then Marchmen at 340ft torque are all garbage as the Dyno was broken. All those runs are all for naught.
MrVermin
we closed up shop by 8pmCmdrData said:How late did everyone stay till on Sunday anyway?
Marchmen said:It's the best stuff I've used. Apparently he gets it from a local shop, but you have to buy 4 of those jugs at once. Group buy?
I apologize if you took my reply to your numbers as an attack. After seeing dyno after dyno of cars with similar mods, 309ftlbs just doesn't make sense. Are you also running a stock clutch?mrvermin said:Well, apparently the Dyno Day on Saturday was all screwed up and henceforth invalidated.
I think he's running a vr6 / g60 setup.LNXGUY said:I apologize if you took my reply to your numbers as an attack. After seeing dyno after dyno of cars with similar mods, 309ftlbs just doesn't make sense. Are you also running a stock clutch?
Only my opinion, you don't have to agree with it..
Regardless, I am sure you are loving the extra power. A tune and nozzles really wake these cars up..
Hey, you're not allowed to recycle clutch excuses at consecutive dyno days. Find a new excuseVwPodRacer said:HAHAHA my numbers can be known since most already know.. im not ashamed of my numbers. for those that want to know it was 199.1WHP! I couldnt buy .9 to get 200whp no matter how hard i tried because the clutch wouldnt take it! but im sure with a better clutch that ACTUALLY holds that i could produce ALOT better numbers but that will have to wait till spring Great seeing ALOT of new faces
hahahaha I do agree with you lol. But... Atleast I showed up and dynoed knowing that it was going to slip! Unlike some other ppl hehe but again I gotta find a new excuse! LolSilver02TDI said:Hey, you're not allowed to recycle clutch excuses at consecutive dyno days. Find a new excuse
Have you ever tried the stuff from Wurth? It's the only thing I'll use. Again, water based so it doesn't dry out your hands. I've had the same 4L tub for over a year. I use it almost everyday.OmegaRenegade said:i for one would be in for 1 big jug of that stuff. it worked great!
HAHA... I made it home safe; and so did the truck. Funny how things work out: Truck got flatbedded to my Shop free of charge <CAA rocks!>, I came back later on.BigI said:... Now where is that guy with his TDI Suzuki?
Not sure how much power It's actually making. I discussed in detail with Jeff my plans for the truck: ie no big power, looking for drivability and mileage. Its a bone stock AHU still on stock injectors, so Im pretty sure I didn't make a 50 hp gain As for the transmission, its really holding up very well! this particular unit was behind an engine that put out a WHOPPING 112 hp@105 ft/lbs or so, now its holding behind an AHU...mo_focus said:he broke the drive shaft after couple of test runs. I guess he was putting down too much power. I think those suzuki's had something like 70hp so when you put in about 140 it might not take it.
